メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年11月7日に発売された、Intel製Core i5プロセッサ、アップデートされたRetinaディスプレイ、その他多数の変更とアップデートを搭載した、待望のリフレッシュ版MacBook Airの修理情報と修理ガイドです。
A1932, Backlight not working, Image & caps lock ok
Macbook Air 13” A1932.
As I was using my macbook it made one “click” sound and the backlight went dark. I can see the apple logo when turning on if I shine a flashlight on it. Caps lock is lighting up and so does the keyboard. I have tried the resetting stuff with the multiple button presses, but no change. I opened the backplate to look at the logic board and did not see any obvious damage, in fact it looks new since I only used it like 4 times.
Is there anything else I can check on this model?
I have read about a backlight fuse, but I don’t know how it looks or where it is located, could somebody guide me to it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
To be clear you are shining the flashlight through the lids Apple logo and can see your desktop? Or if you are in a darkened room do you see a slight glow from the system.
さんによる
コメントを追加
2件の回答
最も参考になった回答
wordi pressi the backlight fuse is reference designator F8400. It is a 32V 3A fuse in a 0603 package. Location on your logicboard as shown. Measure continuity with a multimeter or your can measure for proper voltage with the board power applied.
画像
If it is not the fuse,you will have to check deeper for the cause. Use the schematic for the backlight as provided. Do not forget to check your display connector since a lot of short circuit happen right there. Post some images of your logicboard (both sides) with your QUESTION so we can see what you see.
画像
The image is best viewed by downloading it and using your own image viewer to zoom in.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Check the display cable and see if it's loose. If it's not, replace the display.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I doubt that is the issue. The connection is quite secure unless someone has dickered with it.
さんによる
コメントを追加
回答を追加する
wordi pressi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 24
今までの合計 1,444
