メインコンテンツにスキップ
モデル番号はA1199で2、4もしくは8GB容量
85回答 すべてを表示
Why is there a "do not disconnect" logo on my screen
We just bought a used iPod and there is no booklet with it. When I plugged it in to my computer via a USB connector there is now a sign blinking and saying "do not disconnect". Is there a problem???
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
i am using 7th ipod nano and it says okay to disconet but it just stays there i tried reseting it and puting it on disk mode not of this worked
さんによる
コメントを追加
7件の回答
ベストアンサー
it has a do not disconnect on it because your iPod is trying to talk to the computer. If you disconnect it without first removing it from the computers desktop you can corrupt both the iPod and the computer.
Go to : http://support.apple.com/manuals/#iPod and locate your iPod and download the manual.
Take care
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
最も参考になった回答
This is normal. There is not a problem. You simply have to go into your iTunes program and 'eject' the iPod. The eject icon is a triangle over a bar just to the right of where it lists your iPod on the left column in iTunes.
Roll your cursor over the triangle and press once. After just a couple of seconds, your iPod will be ready to disconnect and the "do not disconnect" logo will disappear.
Good luck,
Frank
このアンサーは役に立ちましたか?
スコア 10
2 件のコメント:
Hi this is also happen to me i see the iPod icon on my iTunes but as soon as i eject it from iTunes the ipod icon goes away...this normal??
さんによる
Hi this is also happen to me i see the iPod icon on my iTunes but as soon as i eject it from iTunes the icon goes away...this normal??
さんによる
コメントを追加
toggle hold switch 5 times, then hold center button and menu button at same time for 10-20 seconds. Sounds crazy, but it worked for me!
このアンサーは役に立ちましたか?
スコア 4
5 件のコメント:
Thank you for sharing this! It worked for me too! I didn't want to have to recover and reset it.
さんによる
but this happens every time i connect it
さんによる
Haha, now my ipod is sad. help
さんによる
it happend every time iconnect it then how can down load music
さんによる
Hey I did what you said and it worked right away. I really appreciate you doing this. So many people have different ways of doing things with Apple but they seem to work very well for me the first try out. You’re the greatest thanks again and keep adding comments and answers for any issues that come up with iPad Mac of any type and OS X programs. Thank you so much for your help
さんによる
コメントを追加
@debbie
Make sure you use iTunes, and connect your iPod.
Select your iPod in the navigation panel on the left, Devices section.
Now use the Music button in the top menu.
Select to synchronize only "Selected playlists".
Only the tracks used in the selected playlists will be synced to your iPod.
The other tracks in your music library will not appear on your device.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Super,works like a charm!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I’ve tried everything and I cannot get the do not disconnect off of my Ipod. Please Help!!!!!! It doesn’t even show my Ipod Icon in ITunes…..
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
exactly the same for me Carmelita !!!!
さんによる
and for me, frustrating
さんによる
コメントを追加
u need to disconnect! If the do not disconnect is still present, theoretically it will boot back into iPod software
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lee さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 28
過去 30 日: 125
今までの合計 36,548
