メインコンテンツにスキップ
Repair guides and support for top and front loading Whirlpool brand washers.
20回答 すべてを表示
Poor agitator movement otherwise ok
WTW4850HW1 When it fills the agitator barely goes back and forth ! Shifter seems ok and I ran diagnostics but no faults ! Does the control board control motor back and forth motion ? Took belt off motor and it runs great !
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hello Brent, when the washing machine is off, empty and with the doors open, can you spin the drum by hand? it should feel heavy, but it also be easy to spin , like a car wheel when it’s lifted up for a tire change. maybe there is something stuck between spinning drum and the main drum , i’ve pulled out dozens of socks out of the drum seal at the front. it also could be the drum bearings, but it’s rare to fail. good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brent Mason さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 50
