メインコンテンツにスキップ
Details and repair information for the LG LFX21960** refrigerator, a bottom freezer model without ice-through-door, featuring both drawer and door access and an automatic defrost system. This page covers information for model numbers matching the pattern LFX21960**.
2回答 すべてを表示
LG LFX21960ST display panel dead, dispense light on ice not being made
LG Refrigerator model LFX21960ST. LG display panel dead, dispense light on constantly, ice not being made and unable to dispense anything. This happened once before in 2019, but the problem went away. When you press any button only the dispenser light dims or goes off. Fridge and freezer work perfectly. There is power to the ice machine, but I believe it won’t make ice because control panel/display is offline.
LG won’t even acknowledge this model refrigerator even exists and seems like an environmental and economical waste to purchase a new one, per only suggestion/solution LG will provide.
Have already tried to cut power to the appliance for 5 minutes, but resulted in NO CHANGE.
If anyone can think of something else to try I am willing to do it. If you know what part is needed to correct this issue, I am also willing to investigate that route. And lastly, I am in NYC and if you know someone local that can assist, that would also be greatly appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @Geoff Gordon,
Here’s the schematic from the service manual, of the power supplies used in refrigerator that may help.
It shows the location of the 15.5V DC, 12V DC and 5V DC power supply test points. Maybe a good place to start, considering that the panel is dead.
Be safety aware when testing as there is lethal 115V AC as well near to where you will be testing.
Here’s the display panel schematic which may also help to find out why it is dead.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Geoff Gordon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 824
