My brake wires are frayed by my handle how can I fix it
Brake wires are coming out at the handle can that be fixed
I would recommend replacing the brake wire that is frayed, which if you know what you're doing can be a cheap and easy fix. Otherwise, I would recommend taking it to a local shop that knows how to repair walkers, or a normal bike shop as bike brakes operate using a similar mechanism and the employees should be able to help you.
このアンサーは役に立ちましたか?
How to fix my handle cable brake on my walker
Can you tell me how to do the fix or show a picture how to fix it
Hi delsea,
Your walker uses the same brake mechanism as the hand brakes on bicycles, so replacing the brake cable is exactly the same procedure. You just need a replacement cable to start with; as @fa1conx has suggested, a bicycle shop should have what you need. If there aren't any shops nearby, it's likely a well-stocked sports shop or hardware store may carry the cable.
Here's a wikiHow article on bicycle brakes that should give you everything you need to know about your walker's brakes.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 5
過去 30 日: 92
今までの合計 983
