Red ethanol for cleaning?
Can I use red ethanol to fix water damage?? The kind used for outdoor cooking devices. My xbox controller has water damage, I think some rust has developed.
Hi Sara,
In the repair shop, we use 99% isopropyl alcohol and a toothbrush. You’ll need to take the controller apart and assess areas you suspect of having water damage. Corrosion usually turns blue if it’s old.
From memory, the controllers use a T9 Security bit. You need to use this exact tool as trying other sizes/types can strip out screws and make it way harder to get into.
The sooner you remove water damage the higher the chances of fixing the issue. Hope this helps.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 71
