メインコンテンツにスキップ
The Xterra was introduced in North America in the 2000 model year (1999 calendar year) and marketed using the tagline Everything you need, nothing you don't.
12回答 すべてを表示
Can a bad valve cover gasket cause smoke from the exhaust muffler
Got a question..can a bad valve cover gasket cause my 2004 Nissan exterra to smoke from the exhaust muffler..im replacing the valve cover gasket right now.. please answer my question please
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Roro Valdez, no it cannot. There may be some oil dripping onto the exhaust (header) and most of the smoke would be in the engine compartment. Smoke coming from the back of the exhaust pipe is caused by the combustion itself. It could be burning oil or coolant. You need to take a look at your spark plugs and see what those look like at the electrodes. If they are blackened, oily and sooted your engine is most likely burning oil. If they are kind of rusted looking it is most likely coolant. The repair of this will be depended on what you find out.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Roro Valdez さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 44
過去 30 日: 168
今までの合計 1,572
