メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ニンテンドー3DSは任天堂の最新モデルです。より大きいスクリーンに、より長くなったバッテリー寿命と改良されたデザインが特長です。
Probably Dead From Water?
So, somehow my 3DS got mixed in with my dirty clothes and I don’t really put my clothes in the washer one by one. I just sorta dump them all in. So, my DS went through a nearly 50min wash cycle. Is there any way I could salvage it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Skye Tor probably not but you can always try. For now you want to stop using it, charging it or trying anything else.
Disassemble your 3DSXL using these guides . You must remove all EMI shields from your motherboard. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for a Apple iPhone all the points are still pertinent to your device. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, you must replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your game and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a least a bad LCD and replacing the display assemblies may fix it. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
If unsure of anything, you can always post some images of what you encounter with your QUESTION. That way we can see what you see. iFixitでの質問に画像を追加する方法
iPhoneの画像
ガイド
iPhoneの水濡れ・水没ダメージからの復旧方法
難易度:
難しい
1 - 2 hours
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Skye Toren さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 128
