メインコンテンツにスキップ
The ASUS Q405U is a laptop produced by ASUS that was released in 2017. It is Intel Generation 5, uses Windows 10 and has many connectivity options.
4回答 すべてを表示
I have certain keys that are hard to work
I need to know what screws I do and do not need to undo to get access to the key matrix and clean it. Top keyboard 1-3, and F1-F4 keys, as well as the area around the “P” key, and backspace key have to be held down, or tapped multiple times to get work. Please help! I have 2 small children and lots of sugary drinks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
It may be easier and possibly cheaper to replace the keyboard (supplier example only) rather than trying to fix or replace the individual keys (supplier example only).
In trying to fix it you may create more problems than what you originally had. If you suspect that liquid damage was responsible then perhaps more keys will also fail soon.
Here’s a video that shows how to remove the upper case/keyboard assembly that may help if you decide to replace the keyboard
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Wesley Tabor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 91
