メインコンテンツにスキップ
モデル番号 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7プロセッサ
214回答 すべてを表示
How to connect display driver board to iMac LCD and use as a monitor?
Hi
I have an old Imac lying around and I want to use it as an external HDMi monitor for different devices. I have looked on the internet and some folks have suggested to buy an LCD display driver board. The model number of my IMAC’s native lcd is lm215wf3 sd d1. Can anyone please guide me on this?
  1. Will this work? Is it too difficult to do as I don’t have an expertise.
  2. What all I will be needing to make it work?
  3. Where can I buy the LCD Driver board? (I live in India}
  4. Is it worth it?
Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@yogiwake if it is worth it depends on you. $50USD for a decent monitor that you can use for plenty of other thing would be worth it to me. It will also keep things out of the landfill and decrease the already abundant eWaste. So, yes!
What you are looking for is something like this straight and easy to install. Not sure where you can get it from in India but you can always try alibaba.com as well.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you so much. The link you have shared, does this include everything I would need? Does it have the inverter?
さんによる
@yogiwake yes it is complete. Remember that there are more than one supplier and more than just one site. Look around and see if anything else is more appealing to you. Maybe closer etc. The link is just an example. The importance here is that you have the panel number since that is exactly what you need to find a universal driver board.
さんによる
コメントを追加
回答を追加する
Yogesh Arora さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 15
今までの合計 519
