メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Earbud repair. Which adhesive to use for reassembly?
First time disassembling TWS earbuds for cleaning.
Before i started, this earbud would play at something like 40% volume.
Soaked my earbud in 99.7% Isopropyl for a day, which definitely got rid of all the wax and i can clearly hear that the volume is no longer a problem.
However the soak also weakened the adhesive inside, and i was finally able to disassemble the earbud.
It sounds like most of the bass is missing, but the rest of the sound profile is fine.
I attribute that to the now-missing adhesive.
I saw two types of adhesive inside, both feeling a bit like silicone adhesive to me.
One adhesive, used i most places, was black.
Second adhesive was white, and only used around the audio driver (presumably to provide a seal around the driver for the bass to work)
white adhesive can be seen on these photos here: https://fccid.io/2AUYFRMA2003/Internal-P...
Should i just use something like B6000 or B7000 adhesive which is used for phone screen repair?
Or is there a different adhesive i should be using?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
I would say that b6000 or 7000 would work fine. Also, a little tip on applying it on small parts is get a needle an syringe and put some glue in the syringe so you have better control (just don’t inject yourself with glue)
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
vitmerc さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 25
過去 30 日: 118
今までの合計 5,020
