Why is my screen stuck at grey
I dropped my calculator and now it won’t turn on. I plugged it in and it started to load, but about 50% in, the screen turns grey (it is not the same loading screen with the clock) this screen is just grey. any advice?
Adi Robinson a grey screen is pretty indicative of a broken screen. Explain the “it is not the same loading screen with the clock)” issue a bit more in depth. Ultimately it does sound like a bad display. Something like this video will at least get you into your calculator. You may need to do an extensive online search for a replacement screen. Places like Alibaba.com or Taobao.com might yield results like this that u can use to get a new display.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 20
今までの合計 451
