UP12/E-LOBR for ATF oil coolig system?
Hello,
I,ve question is good option to built ATF oil cooling system for cooling electric motor with this pomp ? how long can this pomp work, and can i control flow parameter by the SCS or by simple valve ?
Dear @bedkowski, please write to export@marco.it for an analysis of your requirements.
Choosing the right pump is a matter of knowing the required flow, pressure and working cycles and our commercial department can help you with that!
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 10
今までの合計 38
1件のコメント
Hi @bedkowski ,
Perhaps @teof knows. You may have to wait for a response as this is a worldwide forum and different time zones means that there may be a delay before getting a reply. Hopefully not more than a day or two.
Moderator.
jayeff さんによる
