メインコンテンツにスキップ
Logo apple on LCD but wont execute the tiger
Hi, i have a problem with my iMac, the turn on and turn off is ok, but if a few seconds of power on, the lcd is freeze in a logo of apple but not executed the tiger, and do not use on a keyboard and mouse, but in a USB is ok to 5Vcc to power supply and to plugged other keyboard and led keyboard is power on.
¿My problem if a power supply or is possible to de hard disk is dead?
Thanks and excuse my English i am from Spain.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Try starting up holding down the "Shift" key, this may help rebuild the boot sequence.
Try booting from your system installation disk holding down the "C" key. Go to the second screen pull down menu to Utilities > Disk Utility. Select your hard drive in the left hand column and run repair on it till it runs clear then repair the permissions. Let us know your results and if this did the job.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
回答を追加する
carlets さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 10
今までの合計 577
