Why does my car die when put in gear?
It starts great. Stays running but when put in gear & given gas, it's dies & when I push the gas petal it doesn't go anywhere & acts like it's not getting any gas! Please help! ,?
An automatic car can stall when put into gear for countless reasons. It could be a result of a faulty coolant sensor, bad alternator, empty fuel tank, bad fuel pump, leaking vacuum when the filter is blocked, etc.
このアンサーは役に立ちましたか?
If the vehicle idles for several minutes without a problem, and only dies when put into gear, it's probably not a fuel pump or fuel tank issue.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 48
