Nozle hits the bed
Hello, the nozzle keeps hitting the bed. What can I do?
when mine did that i checked on you tube and watched videos on it. one thing is have you done an manual bet level? then adjust the screw on the auto bed level sensor. that would be the videos i would watch
このアンサーは役に立ちましたか?
if the nozzle hits the bed then your z-axis offset is off. you want to go into the settings menu, and then to the bed level option. if while the auto-home part the nozzle hits the bed, you have to options:
A: lower the bed by tightening all of the bed-leveling gears under the bed
B: manually move the z-axis (red circle)
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 12
過去 30 日: 20
今までの合計 475
