メインコンテンツにスキップ
Subaru revealed the third generation Impreza at the New York Auto Show on 2 April 2007—both the standard naturally aspirated Impreza and turbocharged WRX versions were revealed.
3回答 すべてを表示
car started making noise and check engine light came on after new belt
Hey, I have a 2008 manual subaru impreza. In the last couple weeks the serpentine belt was making a lot of noise and was clearly time to be replaced. 3 days ago a friend of mine came around and replaced the belt for me. Looking at how the old one you could tell it was well worn. While lifting the alternator back into place to tighten the belt the bracket snapped. This seemed to have no impact as we were able to lift the alternator into place and tighten the belt perfeclty. There was no movement in the alternator even with half the bracket moving. Later that night I went to take the car for a drive and the check engine light came on, the traction control came on and the cruise control was flashing. There was a very strange noise coming from the engine and had no idea what it was. I quickly turn back home as I didn't want to try the car in that condition. the next day I started the car and the same issue, I checked around the belt and saw the power steering pump was covered in fluid. However, Last night I started it again and the lights were off and there was no noises coming from the car and it was running perfectly. The alternator never moved and the belt kept tension
Really confused about what this could be
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Henry Moffitt things like this are always hard to diagnose since now “the lights were off and there was no noises coming from the car and it was running perfectly”. When you say the light were off do you mean the lights are no longer turning on but everything else is fine. It might help if you add some good pictures of the general area so we can see what you see. It is possible that something was misaligned but seated itself properly after driving the vehicle. The leaking power steering could be a hose, bad connection and other issues. For as long as you refilled the container and it is no loner leaking I would suggest to just keeping an eye on it.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Henry Moffitt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 215
