メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459回答 すべてを表示
droped my phone on the ground the screnn became black
so today i droped my phone on the ground the screnn became black
i think it might be the connector because inside i hear a little thing moving because the that fixed my phone about a month ago i think he didnt put it correctly
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Dropping the phone wouldn’t have helped it much.
The phone had been working for a month after it was fixed, with no apparent problems and the problems started after it was dropped, very coincidental don’t you think?
The best that you can do is to open the phone and check the connection to the display and also inspect for any other obvious internal damage.
I suspect however that the display has been damaged internally and if so, it cannot be repaired. It will have to be replaced.
Here’s the ifixit Samsung Galaxy S III LCD Display/Front Glass Replacement guide that will help.
Replacement displays are available online. Just search for Samsung Galaxy S3 screen replacement
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
gameplay sameplay さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 19
