メインコンテンツにスキップ
Mid 2009 モデル番号A1278 / 2.26、2.53 GHz Core 2 DuoプロセッサーEMC 2326
745回答 すべてを表示
Spilled beer while mixing clickpad doesn't work any advice
So basically I was djing got a little drunk and spilled on my MacBook. It didn't look that bad and everything was still running but ableton got all buggy.
So the next morning (not) I'm sober and the touchpads click is messed up. The click where you press it in. Any advise as to what I should do I have the extended warranty do you think it will be covered?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Usually the warranties don't cover liquid damage. Unfortunately in the new unibodies if you want to replace the trackpad, you have to replace the whole upper case. Unfortunately even more, you may have destroyed the cable connecting the trackpad and logic board, which to my knowledge is built into the logic board in these new unibodies. However, it'd be a good idea to do some disassembly, and look for any residue, if you're lucky that may just be the problem.
Does the mouse not work or is it just the clicking function? A workaround would be to enable trackpad clicking, where you just tap the trackpad to click, instead of actually depressing.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I had tap clicked enabled before so I guess its not the huge of a problem. In addition depressing the trackpad to click which is really my issue still works some of the time after vigorously clicking.
Does this indicate residue and should I crack the case knowing it will void my warranty. I might not be apposed but if apple will fix the issue for less than $250 i might just do that.
さんによる
Possibly, you should definitely open it up.
さんによる
I blew it out with dust off stuck it in a bag of rice and hair dryered it for a bit and now it works next time I'll crack the case though don't worry [ :
さんによる
コメントを追加
回答を追加する
Zac Bolick さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,219
