メインコンテンツにスキップ
A USB (Universal Serial Bus) cable is a common type of cable used to connect devices such as computers, smartphones, printers, cameras, and other electronics. It is designed to transfer data and power between devices, and is often used for charging devices as well.
15回答 すべてを表示
Is it safe to use cable that's dropped into melted wax?
hi experts,
the story is like this…i’m clumsy and i accidentally dropped the head of my iPhone’s USB cable into a 3wick melted wax.
I’ve tried to clean out the wax completely (not sure if all’s out tho) and tried charging my phone with the cable again. It works with no issue.
The thing is I tried searching online but there’s no similar results online. From what I know wax is flammable and should I continue to use the cable to charge my phone? Is it safe to do so? Or should I get a new cable? Please advise!
Many thanks! :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
xuanzaizhou candle wax is flammable when vaporized. So are the essential oils that make those candles smell aromatic. Cleaning the cable properly as directed is always the right thing to do.
さんによる
@oldturkey03
Yes.
Candles are made out of Paraffin Wax. The chemical formula for Paraffin is C 20 H 42. Melting point = 47 to 65 o. C Boiling Point = <188 o. C Flash point = 198 o. C Flame Temperature = 1400 o. C
さんによる
@aactech beats the candles made out of tallow from muttons
さんによる
コメントを追加
2件の回答
ベストアンサー
Hi @xuanzaizhou
The professional solution is to disolve the candle wax by soaking in a beaker or cup filled with 99% isopropyl alcohol (from electronic supply house) for 10 or 15 minutes. Allow to drain and evaporate over night.
The 99% is important as the weaker solution (rubbbing alcohol)can leave residue on the contacts
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
okay understood thanks ?
さんによる
コメントを追加
最も参考になった回答
It should be fine. And candle wax is not flammable or else you would have a very bright burning candle.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
alright noted that's fast reply thanks a lot! :)
さんによる
@xuanzaizhou - But it is an insulator and you could mess-up the socket if you plug it in with the wax on it.
さんによる
@danj
Very true
さんによる
コメントを追加
回答を追加する
xuanzaizhou さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 20
過去 30 日: 53
今までの合計 1,580
