Is there any performance hit when using the transparent back cover?
In the original back cover, there is some metalized shielding and a pogo pin to connect to it near the bottom left side of the battery.
The transparent back cover does not have any metalized shielding for the pogo pin to connect to. I assume there should be some EMI shielding issue or (ground plane for WiFi?) antenna performance hit as a result of using the transparent back cover.
Can anyone confirm the function of the pogo pin to the metal shield on the original back cover?
この質問は役に立ちましたか?
