メインコンテンツにスキップ
The Corsair Gaming K70 is a fully mechanical gaming keyboard with an anodized, brushed aluminum chassis for a professional-grade look and feel. Contoured, textured FPS keys keep you in control if shooters are your game. It’s built with CHERRY® MX switches, and key by key customizable backlighting lets you illuminate your key bindings. 100% anti-ghosting with 104 key rollover on USB helps ensure accuracy, so every keystroke translates directly into accurate gameplay.
3回答 すべてを表示
Corsair Gaming K70 RGB Quickfire - Remove Screws for Front Panel
To detach the front panel it requires some hidden screws to be found and unscrewed first: Where and how does one access all the screw locations?
There are two hidden screws, one looks to be under the ‘Corsair’ logo, but not to succeeding at removal even when willing to cause damage, and the other screw is in the top-right corner beneath the right side of the ‘audio wheel' panel.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Just pulled a K70 LUX RGB Apart and I can confirm that you need to remove these two hidden screws. You can remove the logo carefully with a utility blade. The plastic cover to the right of the volume wheel also needs to be removed pry it open from the top or bottom not sure how it should come off it is a semi circular piece of plastic. There are another 22 Phillips #000 Screwdriver screws for a total of 24 screws. Good Luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Zynj さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 36
過去 30 日: 158
今までの合計 1,067
