Replacing removed key on MBP 14?
It looks like my cat removed the down arrow key on my laptop. Any recommendations for putting it back on? Apple Support didn’t know what to do other than recommend that I go to my nearest store 2 hours away.
Update (01/19/2022)
Figured out the solution! When you lift the right side of the scissor switch, it also lifts the left. While the left side is lifted, you can slide the key (tipped on its side to the left) under the lifted left side. This allows the switch to drop into the clip on the key. The key can then be dropped down and snapped in on the other side.
この質問は役に立ちましたか?
