メインコンテンツにスキップ
The first generation Neon was introduced in January 1994 and manufactured until August 1999. It was available as a four-door notchback sedan and a two-door notchback coupe.
29回答 すべてを表示
締切られた回答
locate pvc valve and replace
i need to help to change the pvc valve on my noen because if i dont push the gas on the car loss power and want to shut off and i change the oxigen sensor and still same so my mecanic tell me to change the pvc valve i need to to know where is it and how replace
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The PCV valve is locate by the intake manifold. Download the emission part of the service manual from here. It will give you a description how it works, how to test and how to repair. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,481
