メインコンテンツにスキップ
LG G4は2015年6月上旬に米国で発売され、いつものようにハイエンドの仕様と、プレミアムスマートフォン市場で際立つ洗練されたファッションセンスに焦点を当てている。携帯電話の各バージョンは、キャリアによって販売されているか、ロック解除されているか(米国または国際)により、異なるモデル番号を持っています。一部のLG G4にはブートループの問題があることが知られている。
Why is my phone not turning on?
Hi, I'm Vaughn. I have a silver LG G4. It was working fine, until about early December, last year, when it got really cold, and I forgot that my phone was in a white case, and somehow, it wouldn't turn on or charge, and I had just replaced the screen.
Usually when I turn the phone on, the phone vibrates and the screen comes on, and when I charge it, the battery icon would come on the screen, then the orange light, but none of those things happened.
I really need to know what's causing this, and how my phone can finally turn on again, so I can finish copying over some data to a new device. Please help me. thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Vaughn Gracey the very first thing you want to do is change your battery. If that does not work proceed according to the LG flowchart. Repair is War on Entropy. Tossing it is not what we want to advocate around here. It’s iFixit not iReplace it (within reason;-)
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
Now, bear in mind why I said what I did. I got cinged by LG with this phone.
さんによる
@nick I hear you but opinions do not help the OP ;-)
さんによる
@oldturkey03 It's often the board, especially early models. Yes, this *does* sometimes fix it, but if it did, I'd be rushing to get the data onto a new device and let the G4 fail naturally.
If someone gave me one I can unlock I'd totally run it until it died but not as a main phone.
さんによる
@nick I know but our opinion should not matter when we answer. Let the OP make the decision on how and what they want to fix. Every answer should be unbiased and objective despite on how we may feel about the device. Not our call. ;-)
さんによる
@oldturkey03 Well true yeah mine was a confirmed board failure how it failed based on the issue, plus failure mode. This one is greyer since the symptoms of failure don't point to it as readily.
The LG DAC is really good especially for 16-bit FLAC (sadly I never got to test 24-bit FLAC) so it's sad their phones had so many problems in a way. I remember just how good Pure Heroine (ripped from the Japan release with the bonus tracks) sounded on the LG DAC - the dual DAC was even better, but the G4 colored my taste for LG permanently. I haven't found anything as good since.
iPhones do not work for me since I can't install foobar2k and put a 256GB MicroSD card in them.
さんによる
コメントを追加
回答を追加する
Vaughn Gracey さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 31
過去 30 日: 143
今までの合計 360
