メインコンテンツにスキップ
これらの部品交換DIY修理ガイドであなたのMotorola Edge Plusを修理してください。
Phone not saying turbo charger connected
My phone says turbo charger connected when I plug in the charger. Recently, my phone does not say this when plugged in. I bought a new one thinking the charger was broken or old but this issue is still happening. I'm not sure what's going on. Can you help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
My Moto G6 also doesn't show this message sometimes when turbo charger is connected. I need to connect & disconnect twice or thrice then message appears & charging starts. When connected & disconnected as above, then, invariably, after charging, phone shuts down automatically when my first call ends. This automatic shutting down surely takes place when message doesn't appear in first instance when charger is connected. If message appears at first instance when charger is connected, then phone doesn't shut down. Can anyone help me to rectify problem?
さんによる
コメントを追加
7件の回答
最も参考になった回答
I had the same issue recently and realized I had the wrong cable connected to the charger and phone and as soon as I used the correct cable I got the TurboPower connected message.
Also if the phone is over 78% charged the turbo may not display.
Let me know how you make out with this issue.
Mike
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
now the opposite happens for me. Above 78% it charges using turbopower and below it only charges radpidly, which takes 1.5 hrs approx to reach 80. (All this using the stock charging cable, other charging cables work as usual)
さんによる
コメントを追加
Try flipping the charge cord over...no bulls**t it works for my moto g power on all my charge cords...one way regular charge the other turbo
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Try turning the charge cord over in the phone and make sure you're using a n actual turbo charger
さんによる
This actually worked! Thank you!
さんによる
Im having to do the same ol flip over trick for my MOTO EDGE + 5G. Now its giving trouble again.... Any other suggestions??
さんによる
コメントを追加
This usually doesn't happens much in Motorola phones until they are 2-3 years old. However, if it's not showing turbo charging then you can check once in your settings and battery health to see what kind of charging is happening.
You can get your charging spot/jack changed and mention that you need a turbo charging jack.
I had the same problem a couple of weeks ago, it's sorted now.
All the best 😀
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
さんによる
コメントを追加
My wife and I both had Motorola Edge + and both our USB ports failed. Mine was repaired and it failed again within two months. The Edge + is the first flagship they make and obviously, they need some tuning. Our phones also couldn't connect well to Android Auto Wireless. We changed them for Samsungs and everything is fine now.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I blew my port out with an air paint gun, which seems to have worked for me. If you have a can of compressed air I would think that would have the same effect.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Unfortunately, that wasn't the issue. It tried that multiple times and it didn't work. I ended up going to a phone repair shop that diagnosed half my USB-C port had died and replacing it was 150$
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Used to have the same problem and had it diagnosed by a professional that half my USB-C port had died. Had it changed under warranty and it failed again after 3 months. Now I charge it wirelessly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jeposey さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 110
今までの合計 10,120
