メインコンテンツにスキップ
モデル番号はA1059もしくはA1099/20、40、60GBハードドライブ/タッチ反応クリックホイール
Why does my iPod show charged when it's not?
I recently bought a iPod classic 4th gen to repair, bought it expecting to replace the drive but found that it just wasn’t fully plugged in. So the iPod booted, I was able to reformat it and put some songs onto it. The issue I’m now facing is that it won’t fully charge and the small amount of charge it does get it won’t hold for very long. I’ll plug it in and it’ll charge for 10-15 minutes before showing the charged screen and when I unplug it the on screen indicator will show only around 20% charged. I’m assuming it has a bad battery but I just want to make sure that I actually need to buy a new battery and if it’s not some small issue. I’ve also tried with different cables getting the same result.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@mrslic all the issues you are describing sound like a bad battery. I would go ahead and replace the battery with a good one and see what happens. iPod 第4世代またはPhotoのバッテリーの交換
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yeah probably, I'll get one ordered just wanted to make sure it wasn't some obscure issue I couldn't find elsewhere. Thanks a bunch!
さんによる
コメントを追加
回答を追加する
Mr Slic さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 144
