Why my phone is not turning on?
my phone is not turning about to 7 days. I tried all the methods like releasing power button and volume buttons and blow drying what to to now?
My phone is not turning on from 4 months I show to this mobile many repair shop
このアンサーは役に立ちましたか?
Krishika Sahay start with your charge cable and charger. Make sure that it is in good working condition and that it supplies the power needed for your Xiaomi Redmi Note 6 Pro. After that check the charging port. make sure there is not dirt/lint etc in it. a few puffs of compressed air should clean it out. After that you will have to start thinking about disassembling your phone and check with a multi meter that the charging port is properly connected to the board. Replacing the battery will also be necessary to ensure that is not the issue.
このアンサーは役に立ちましたか?
Its only showing charge when I was charging my phone miui logo redmi logo and charger is in good condition
@Krishika Sahay start off by changing your battery. Your phone may show that it is charging but your battery may not hold a charge. This way you would also have a Known-Well starting point for future troubleshooting.
過去 24時間: 0
過去 7 日: 7
過去 30 日: 41
今までの合計 1,680
