メインコンテンツにスキップ
Released in January 2018, the ThinkPad T480s is a slim version of the T480 with the traditional trackpoint and three-button trackpad.
6回答 すべてを表示
Power button and keyboard keep blinking when I try to power on.
When I try to power on the power button and keyboard keep blinking.
I did try removing the battery and re-seating it but that did not help.
I will appreciate any assistance as I am in an remote area and need my laptop to access my data on it.
Thanks and Regards
Aataish
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hi @navnins ,
Try a full power refresh and check if that resolves the problem.
Here’s how:
i). Disconnect the charger if connected and shutdown the laptop if on.
ii). Disassemble the laptop and remove the main battery.
iii). Disconnect the coin cell RTC battery from the systemboard. Here’s the hardware maintenance manual for the laptop. Go to p.76 to view the necessary pre-requisite steps and then the procedure to remove the coin cell battery.
iv). Press and hold the laptop’s Power On button for a full 30 seconds and then release.
v). Reconnect the coil cell battery, reinsert the main battery, reassemble the laptop, connect the charger and try turning the laptop on.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Reseat the ram it maybe bad ram I would loop up light codes online it will tell you what is wrong with it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Aataish さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 91
今までの合計 5,877
