メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年9月発売のパナソニック製デジタルカメラ。光学60倍ズーム、HD動画・音声が特徴。
Flash does not light up
I have a FZ72 (which is very similar to FZ70).
The flash does not work. If I open it, the camera recognises it and also preloads the flash. But if I press the button to take a photo, the picture is taken and no flash lights up.
I assume the cables could be broken, because for some time the flash only worked, if I pulled the case of it a bit backwards.
My question is, what is the tiny blue device behind the flashlight. Also there are 4 cables altogether. Which could be broken? Is it possible to fix it at all?
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @hilfs08,
Check the capacitor and the connections to the capacitor are OK. This component provides the power for the flash to operate.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Unfortunately this did not help. The cables to the flash are covered on the flash-side by rubber, so you cannot measure anything. However I tried to discharge the capacitor and it recharged after turning on, but still no flash. :/
I assume the cable is broken somewhere, but since it is tightly attached to the light itself, I would have to find a new set somewhere...
さんによる 共有
コメントを追加
回答を追加する
Phil さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 26
今までの合計 796
