メインコンテンツにスキップ
Panasonic Lumix DMC-FZ35 High-end Digital Camera - Black DMC-FZ35K 31
4回答 すべてを表示
How to clean the lens zoom mechanism
My camera is a DMC-FZ38., which looks the same as the FZ35.
After not using it for a while, when I switched it on I got System Error (Zoom). I found advice here to bash the sides of the camera gently while switching it on, and after several attempts, the zoom lens started working normally.
However, this suggests there may be dust in the mechanism, so if I just ignore it, I’m likely to burn out the wires to the stepper motor.
How should I go about cleaning the mechanism?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Hi @robclack ,
Don’t know the camera but here’s the service manual that may help.
On p.22 it shows how to view the error code history. Using this you can work out if the zoom lens has caused any error codes and what they mean. (see Attribute - Lens, Sub item - Zoom on p.23).
On p.29 there is the dis-assembly flowchart and on p.36 it shows the zoom motor unit.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks, Jayeff. I couldn't get the instructions to display the error code history to work, but in any case, dismantling the camera looks way beyond my capabilities, not least because it requires a clean environment, which I can't provide.
Assuming any dust came from the front (asking for trouble, I stopped using the lens cap 1,000 years ago after it wore out!) I plan to zoom the lens out to maxiumum then use and air brush to blow on it in the hope of dislodging any dust.
If it jams again, I'll have to decide whether to replace the camera or just stick with my phone.
All the best
Rob
さんによる
コメントを追加
回答を追加する
Rob Clack さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 229
