A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
You haven't named the motherboard make, model number and revision version. You will need to open the side panel and look at the board markings. While there look at the power supply. Its details are usually marked right on its side.
28 件のコメント
Hi @erikasss ,
More information is needed to help you.
Make and model of motherboard?
Make and model of GPU card?
Amount of ram?
Wattage of PSU?
Does it only happen on games?
Does the PC meet the minimum system requirements for the games that fail?
Have you checked that the video drivers are the latest version for the GPU card?
What have you checked?
jayeff さんによる
CPU - intel core i5-4570, 3.20 GHz
GPU- GTX 1060 6GB
RAM - 16 DDR3
PSU - I don't know honestly
That also happens when I try to watch some YouTube videos or just when I search something in my browser
On GTA V pc don't meet the minimum system requirements but it also crashes , on F1 2021 pc meet minimum system requirements
My GPU have the latest drivers version , I also tried to uninstall drivers and then re-install but that doesn't help .
Also when my pc is on on the screen appear grey colour
Erikas Asakavicius さんによる
Hello @erikasss
mike さんによる
@erikasss
Check for any Critical, Error or Warning events that may be logged in Event Viewer at the same time as the problem occurs.
To get to Event Viewer in Win 10 press the Win key + x key (both together) and click on the Event Viewer link.
You said that it can also occur when browsing, so try starting the PC in safe mode with networking and check if it happens when browsing.
If it doesn't you may have a driver problem
jayeff さんによる
@aactech
Motherboard-Asus B85M-E
My PSU is MX F1 but I don't know how many wattage it has
23件以上のコメントを表示
