メインコンテンツにスキップ
The Lenovo IdeaPad S540-15IWL is designed for students, featuring a 15.60-inch display and powered by an Intel chipset with a Nvidia GeForce GTX 1650 Max-Q graphics card, aimed at providing a balance between educational needs and multimedia performance. This laptop, notable for its slim aluminum design and easy maintenance access, runs on Microsoft Windows 10 Home 64 Bit and includes user-friendly features such as a webcam with a shutter and fast charging capability.
1回答 すべてを表示
Anyone know how I would go about removing the DC Jack?
I got the laptop completely torn down and have a replacement jack. I could not for the life of me get the DC Jack to come loose. I tried a heat gun and soldering iron and it won’t budge at all. Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@thebiguke definitely no fun. Use of Kapton tape on surrounding parts will be required. Preheat the board (I try to keep it around 80 deg C to 90 deg C) Then use lots of flux, soldering braid and a nice chisel tip for your soldering iron should work. As for temperature, I use whatever melts the solder since it should be quick and hot to melt it. To cold it will not melt the solder properly and potentially you’ll tear the traces; to hot and you’ll melt the solder pads on the motherboard. It does take practice….
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
TheBigUke さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 67
