galaxy A51 it will charge from my computer but not on a wall
I have a samsung galaxy A51 it will charge from my computer but not on a wall is there a usb tab in the phone that might have switch to only charge usb how can i fix this issue
Hi @hjubela,
Have you tried a different compatible wall charger, you didn't say?
The problem may be with the wall charger since the phone charges OK from a computer. This is assuming that you're using the same charging cable to connect between the phone and the computer and between the phone and the wall charger.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 290
