メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Power/Sleep and Home Button Unresponsive
I have a iPod Touch 4g which has a cracked screen. I replaced it, and still didn't put it back. I attached the two wires from the screen to the iPod, and now the Power Button and touch screen are not working. I plug in my charger, and it goes to the password screen, and I can't slide it.
How can I fix this?
EDIT: The volume button also don't work :/
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
Assuming that everything worked well before, the #1 culprit for malfunctioning electronics after dis-assembly tends to be dirty or poorly seated connectors. Clean everything well with a high-content rubbing alcohol and make sure the connectors are seated fully. If that all checks out, closely inspect each of the connectors and see if a pin was damaged. Good luck and let us know what you find!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I tried this, and now the display doesn't light up anymore when I plug the charger in :(
さんによる
コメントを追加
It is most definitely a damaged on/off, volume flex cable. There is a post elsewhere on this site.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Cytonic さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,009
