メインコンテンツにスキップ
Repair guides and information for kitchen food scales.
27回答 すべてを表示
Why does my scale not read reliably or return to zero reliably?
Duronic kitchen scales KS865 - wheatstone bridge strain gauge-based balance.
The scales tare correctly, but when I place an object of known weight on it reads low. When I take that object off it does not quite return to zero. The scales have recently been dropped.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I found that the load plate (top part) of the scales had become slightly twisted in its mounting (through the strain gauge) to the base of the scales. This was causing the load plate to rub slightly on the base and make the readings unpredictable. By slackening the two screws that mount the load plate to the strain gauge, and realigning, I was able to get the scales working perfectly again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
dan_6384856255 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 84
