plastic connector broken that connects band
The plastic connector on the watch is broken. One side of band wont connect to watch
Can it be repaired watch works fine
Hi,
I can’t find an individual band holder part listed online but have found this which includes the band holder.
A cheaper option to consider is to get something like this and place the device in it
このアンサーは役に立ちましたか?
Great idea!
Thank you!
My connector just broke and since it's past the warranty couldn't get it replaced. Fitbit offered me a discount on a new one but going to try out the holder from Pinnacle Luxuries first. Thanks for the help!
過去 24時間: 3
過去 7 日: 35
過去 30 日: 106
今までの合計 8,661
3 件のコメント
My Fitbit Charge 4 band will not fasten to the watch as the clips on one side are broke off. Also my large band has been splitting apart in several places .Is it possible to get the parts to fix it.?Thank you
Donna Thompson さんによる
@Donna Thompson
See answer below
jayeff さんによる
The band on one side was easy to release; the plastic connector on the other side
came loose from the band end. I can’t get the connector to come out of the slot. Tried to remove by pressing the release button. Didn’t work. Used small pliers and pressed button simultaneously but it didn’t come out. Ideas for removing it?
Malcolm Peterson さんによる
