メインコンテンツにスキップ
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418回答 すべてを表示
will the later 2007-2008 lower case fit a 2006 core duo?
The battery hold down lock in my 2006 core duo is defective. I do have a few nonworking 2007-2008 Core2duos at hand with good lower cases. Are they interchangeable? Ifixit’s parts numbers are different, but maybe there’s a hack that will work?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
I am 100% sure it will work
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Assuming you'll be porting over all of the other internal components (the heatsink, the fan, AirPort card, MagSafe board, battery connectors), etc, it should be possible to transfer your Core 2 Duo motherboard over. The main thing to be watchful for is that the screw standoff positions may be different in the Core 2 Duo A1181 bottom case. The easiest way I can think of is to look at the compare the final images of the bottom case for the iFixIt Lower Case replacement guide between the Core Duo and Core 2 Duo MacBooks...but even then you potentially won't know for certain without attempting the replacement.
If the screw positions do differ significantly, you may have to cut any conflicting screw bosses off of the bottom case (i.e. with a Dremel) to accomodate the motherboard.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bernie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 55
