How do repair the battery connectors
How do you repair loose battery connector on gba sp
shermad32 loose where? If it is loose on the board you will have to look at the motherboard. The battery connector is soldered to it. Double check those solder connections. Use this guide Nintendo Game Boy Advance SPのバックカバーの取り外し to work on it and you are looking at this connector
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 17
過去 30 日: 31
今までの合計 641
