メインコンテンツにスキップ
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
48回答 すべてを表示
Panasonic DMR-ES30V will not turn on
My Panasonic DMR-ES30V will not turn on. I've pushed the power button, changed the batteries in the remote, changed power outlets and changed the power cord. I worked fine a few months ago. Can it be repaired?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@plankowner3 your Panasonic has a fuse on the inside by the power plug/cord. You may get to it from the rear of it. Check to make sure that A. The fuse is good (has continuity) and you can check with a multimeter if there is power on it. Careful, this is full household current on it so you don’t want to stick your fingers on it etc.
If you can, post some good pictures of the unit itself and/or the boards when you have it opened up. That way we can see what you see. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi @plankowner3 ,
To add to the answer here's the power supply schematic from the service manual that may help.
さんによる
コメントを追加
回答を追加する
William A Scott さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 18
今までの合計 182
