My sansung mega powers on but wont go past spinning ATT logo to go int
My sansung mega powers on but wont go past My sansung mega powers on but wont go past spinning ATT logo to go into activaty ATT logo to go into activaty
@Richard Streander
Try holding the power button operated for a full 30 seconds after removing the battery.
Then reinsert the battery and check if it restarts automatically or if you have to start it using the power button.
If it doesn't restart automatically try starting in safe mode and check that it works OK and that you can turn it off normally.
このアンサーは役に立ちましたか?
Hdy thankyou jayeff im trying right now
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 109
4 件のコメント
What happens if you shut down the phone, then hold power+volume down for a few seconds?
Andrew S さんによる
Thanks for helping im trying that but it wont actually shut down it keeps rolling over into restart
Richard Streander さんによる
@Richard Streander Can you disconnect and reconnect the battery?
Andrew S さんによる
Yes andrew thsts the only way i could shut it down then i put battery back in and same Start up sequence until ATT logo stays stuck tried your volumn and power hold and ut just would reboot still not getting past logo
