メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
日本の電子機器メーカーであるHitachi(日立製作所)のテレビに関する修理ガイドおよび修理情報です。
TV has black screen but has sound. Works after months unplugged
Hitachi TV, can hear sound from it.
  • Have tried unplugging from wall and leaving for an hour.
  • Tried plugging directly into wall
  • Tried holding down power button for 30 seconds then plugging everything back in
  • Red light blinks when plugged in, but when you try and turn it on light disappears and no screen change
  • Shone light against screen to see if a back-light issue (it's not)
  • Tried unplugging the HDMI cables that were in and using different ones
Honestly we gave up and left it for a couple months. On a whim we plugged it back in and… It worked??? Was good for a couple weeks but today tried to turn it on and it's dead again.
The fact it came back to life after months is baffling to me. Any ideas what would cause this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント:
How old is this TV? Can you post pictures of the boards in the TV? iFixitでの質問に画像を追加する方法
さんによる
It's nearly 3 years old. But still very confused what component could fail and months later work again
さんによる
@emma.brady12 Can you upload pictures of the boards?
さんによる
emma.brady12 what exact model is your Hitachi TV? Wile your TV has sound and no picture, in a darkened room shine a flashlight beam at an angle against the screen. See if you can make out shapes or silhouettes. This will not work on Plasma TV's etc. so we need to know the model for sure.
さんによる
コメントを追加
2件の回答
Unplug the HDMI from one input and plug it to a different input to test if a port is bad. Replace the HDMI cable as it may have a short or another defect which causes the black screen issue. Unplug the TV for 5 minutes to attempt a reset. Unplugging the TV will reset the television and clear any temporary issues.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
As mentioned above, have tried unplugging it for many minutes (hours even) and it makes no difference. Have also tried each HDMI port using different cables for each, and also having none plugged in at all. I don't even see the hitachi logo pop up on the screen which it usually does when booting.
さんによる
That's weird. How old is your TV?
さんによる
I have this problem. Unplug all the leads in the back of the TV as well as unplugging it. Leave for twenty minutes. Plug all leads back in. Then should work. No idea why this happens but mine keeps doing the same if I don't use it daily. Went away for the weekend and it dud it again! Working now.
さんによる
コメントを追加
emma.brady12 what exact model is your Hitachi TV? While your TV has sound and no picture, in a darkened room shine a flashlight beam at an angle against the screen. See if you can make out shapes or silhouettes. If you can, you know that it is the backlight that has failed. Since it generates an image, that would be excluding the main board and most likely is a failed backlight array. If there are no images etc. It is possible that this is the T-con board, or the man board not telling the power board to turn the backlight on. Board failures are usually registered by the TV's firmware and would generate a power LED blink code error. This will not work on Plasma TV's etc. so we will need to know the model number.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
emma.brady12 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 41
今までの合計 4,467
