メインコンテンツにスキップ
このモデルは2016年に発売されました。2013年に発売されたCUH-ZCT1に変わる後継機です。コントローラーは前モデルと類似しています。
267回答 すべてを表示
Is it possible to fix scratched circuit film?
I was checking my joystick because it drifts a little but when i open the green thing, i just accidentally scratched my circuit film, and the D-pad didn't respond when i connected it to the console.
Is it possible to fix the scratch or buy another one?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@fixie_t you could try a scalpel to carefully scrape the covering of each off the trace then use something like a circuit writer pen to connect thos. By the time you have all those materials the cost is probably higher than replacing it. So check prices and see if you are A. comfortable with doing this and B. which is more economical/available.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I think i can buy new circuit film because it’s cheaper than pen. But thanks for the answer.
さんによる
@fixie_t makes perfect sense. Good luck with your repair.
さんによる
@oldturkey03 i think i bought the wrong circuit film. My scratched film (as you can see on the image) is jdm-50 and the thing i bought was jdm-40(i bought it on amazon and it was just like the same as my scratched one). But i wonder if it still works if i put it on my DS4.
Then when i replaced it with the new one, all buttons actually works except R2 and L2 buttons.
さんによる
It may or it may not. All it takes is one connection changed and it won’t function as you need it. I’d try and get the proper part for it to ensure compatibility
さんによる
コメントを追加
回答を追加する
Takumi Terui さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 17
今までの合計 371
