What is causing a yellow smudge across the bottom of pictures
Yellow smudge across bottom of screen on my Z712 IS
I’d recommend viewing the pictures on a computer to see if the smudge transfers to that as well. If not, it’s most likely just going to be a problem with the viewfinder. You’ll probably be able to find the part pretty easily. If it does show up on a computer, check the internal components behind the lens and make sure that they are clean.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 24
