メインコンテンツにスキップ
The Plantronics Voyager Legend is a wireless, Bluetooth enabled headset, which is compatible with most cellphones available on the market. Originally released in September, 2013, this device is still popular among a wide variety of users.
22回答 すべてを表示
Do battery replacement instructions also work for Voyager 5200?
The Plantronics Voyager5200 looks almost identical but is in fact different (Rtings has side-by-side pictures). Do the battery replacement instructions for the Legend also work for the 5200? Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
basically yes they are almost identical. Just be sure you get the right battery with the right leads.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Did you actually perform a battery replacement on the headset? I am sure that they are identical from the inside, but the fastening of the case looks quite different, if you look at the pictures.
さんによる
@jastram I did it on the new one. They are the same type of pressure snap clips so be gentle when you separate.
さんによる
@jastram
https://www.youtube.com/watch?v=oXuHwYJv... (Legend)
https://www.youtube.com/watch?v=odVpATQO... (UC)
Hope this helps a bit more than me just saying it's very similar!
さんによる
Those videos are useful, thanks. In fact, they show that disassembly is easier than with the Legend.
さんによる
@jastram not a problem. if this answered your question please chose an answer but if you have issue you can still come back and ask
さんによる
コメントを追加
回答を追加する
Michael さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 29
今までの合計 345
