Thw laptop screen does not working? How to fix the diode?
Just LENOVO is giving when sturtup the laptop. Further black screen is giving
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
What diode??
Have you tried connecting an external monitor the the laptop and check if there is a display on it when the laptop has booted into Windows?
When the laptop is on, try shining a torch at an angle close to the laptop screen and check if you can detect any images. They will be very faint if they are there. If you can see images you have a backlight problem.
このアンサーは役に立ちましたか?
Thanks for the answer.
Firstly the the system required a bitlocker recovery.
Than i conected with other monitor and the laptop screen somehow works.
Thanks
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 194
