メインコンテンツにスキップ
LG Stylo 5 is an Android smartphone that was announced in June 2019.
26回答 すべてを表示
(im pretty sure its this type of phone)
i cant tell what phone it is i just know its an lg stylo and it looks to be this one but when i charge it. it only turns black and vibrates over and over again every like two seconds. it shows the red led light and every once and a while when i try and turn it on the top of the screen will flash grey then turn completely black and continue to vibrate
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@tangentzebra927 all of these “only turns black and vibrates over and over again every like two seconds. it shows the red led light and every once and a while when i try and turn it on the top of the screen will flash grey” is a pretty good indication that your phone cannot find the display. Most commonly caused by a bad display. Now to assist you further with this you will absolutely need to know what model your phone it. There is most likely a sticker with the serial number, in the battery compartment but it may require a bit of work to remove the back cover.
Update (11/22/2021)
@tangentzebra927 this video will work for the repair. For the replacement display, do an online search. The costs will vary but looks like USD $20- USD $30 should get you a replacement.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
its lg stylo5
さんによる
コメントを追加
回答を追加する
Brennan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 24
今までの合計 300
