メインコンテンツにスキップ
Samsung un55ks8000 turns on but black/gray image power light blinks 7x
My Samsung un55ks8000 started having this problem where when I turn on the tv all I see is a grayed out image and the red power lights stays blinking 7 times. Then it power cycles and keeps repeating the same steps.
Any idea what it could be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
この回答は他の質問に帰属しています。
So I was able to get the TV to turn on and return to working order by taping 3 of the lines on the ribbon cable inside the TV. I followed instructions on a video online. Right now everything is working but I just want to know if this fix will stay and if there is something more permanent like replacing a part which I can do . Any info would be appreciated
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
@godfather17 which video did you check so that we can see what lines you taped....?
さんによる
There are several videos online. One in English and one in Spanish
さんによる
Esse defeito é a tela, não compensa financeiramente trocar.
さんによる
コメントを追加
回答を追加する
Godfather17 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 19
今までの合計 182
