メインコンテンツにスキップ
キャッシュレジスターの修理ガイドならびにサポート
53回答 すべてを表示
G800 SD electronic cash register
Hi how are u hope ur fine, ,may kind assist me with my G-800 SD electronic cash register,, the upper black button that use 3 keys is missing ,the one that is used to control the use of the cash machine I don't know how i missed it ,and the machine is still brand new never 4been used before, may you kindly help me with replacing that button and please assist me with giving me giving me the user manual again I misplaced it. thanks you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
You can get the manual for this cash register at https://data2.manualslib.com/pdf4/88/872...
さんによる
コメントを追加
1 件の回答
https://www.manualslib.com/manual/872656...
here is a search for repair places. you can call and order what you need but there really isn’t much online as these are basically a closed parts system like ATMs are.
https://www.google.com/search?q=nts+cash...
however if you are referring to the keys that unlock it for use than you can also get them from these places but you will need the serial and model numbers off the register. usually these are a stick on the underside of the unit.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Eva Mogale さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 146
