Super glue for back glass
Hello,
is it possible to use super glue for the back glass repair? Will it get stuck if I don’t place the glass correctly first try and I want to move it around a bit and will it stay or move after correct placement?
You need to buy good super glue which is also know as CA glue. you want the thinnest type. you will also want to buy activator. Place everything in it’s spot and using a fine glue tip fill the spaces without moving them. you should have 2-5 minites to do this before it gets to sticky. Also make sure it is bone dry and as dry air as doable within reason. the water in the air speeds up the curing. When you are happy with it spray on the accelerator you bought for it at the same time.
Test spray the activator elsewhere so you know how fast it comes out as you don’t want it to move the fix.
https://www.amazon.com/dp/B00BUVAZ5S/ref...
https://www.amazon.com/Starbond-Cyanoacr...
and the Oh crap bottle
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 690
